Glycol
BillyO
Member Posts: 277
Is Hercules original anti freeze (Blue) already mixed down to 45% Glycol? I want to run system at 40% glycol, would I only need to dilute 5% down to 40% ?
Do you know which version of the Hercules you have? This is the most common.
Use the chart on the container to get the freeze protection you want. That varies from different blends, so % is not always the same.
To boost an existing system without knowing the volume of fluid would be a bit of hit and miss. I kept a container of 100% fluid to use for boosting. Using a premix glycol may waste a lot of purge to get to the level you want
Check with a refractometer to see when you get to the rate you wantBob "hot rod" Rohr
original cryotek is Blue. The customer support at Oatey said the blue is 45% glycol out of can0
What freeze and burst temperature are you wanting?
I used the Rhomar Ultra for boost, it is straight glycol. Looks like the Hercules 100 may be also.
The price is another indicator of the strength of the fluid🤔Bob "hot rod" Rohr
Living the hydronic dream1 -
Hercules AG is also blue and is concentrated to 95% glycol. Buy a refractometer they are cheap and measure your desired mix. https://www.amazon.com/s?k=refractometer+glycol&crid=11O1R6RQSTD4T&sprefix=refractometer+,aps,362&ref=nb_sb_ss_ts-doa-p_4_142
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
