Hydronic System Not Sending Heat(water) for 1 out 4 zone.
ggx
Member Posts: 2
in Gas Heating
I have a GWA-105-N-T and for 1 out of the 4 zones I don't feel any heat in the baseboards of that zone.
Here is the steps I did to test:
1. I turn on the heat in my thermostat
2. I can hear the valve gear turning, then some water(cold at this point) would flow through and I also hear water flow sound for a few seconds at the baseboard.
3. Furnace would start(then stop when it reaches 180f),
4. But the hot water is not reaching the baseboards, and when I touch the pipes around the zone valve , it is lukewarm.
5. Return pipe is also cold.
6. It feels as if the zone value opened then closed by itself? Is that even possible.
Thanks
Thanks
This appears to be air in the closed loop. Do you know how to remove air from your baseboard loops?
Thank you for the suggestion, I find this video youtube, would you say this would be the steps to follow to try?EdTheHeaterMan said:This appears to be air in the closed loop. Do you know how to remove air from your baseboard loops?
https://www.youtube.com/watch?v=z80WspC4Nmg 0
