Small leak
Mike_reichert
Member Posts: 2
in Oil Heating
Hi I have a peerless boiler and I’m getting a small drip from this Anyone know what it is and how to remedy the problem
That is an air vent. ...and not just any air vent. It is a micro bubble air vent. I have not had much success with taking them apart to repair the float valve inside them.
Those threads on the end are 1/2" pipe thread. As a temporary fix you can add a 1/2" coupling with thread sealant (like teflon tape or pipe dope) then place a 1/2" close nipple and a 1/2" pipe cap on the threaded end to seal it until the off season. Then you can get a professional to come and repair or replace it.Edward Young Retired
is there a way to get it to stop dripping0
Take it apart and get the valve inside there cleaned out. But I would wait until the spring. just put the cap on it for now.Mike_reichert said:is there a way to get it to stop dripping
I’d be quite impressed if you can dis and reassemble the valve mechanism on that air purger. Here is a common fix😁. Or buy another and swap the top part.Bob "hot rod" Rohr
Living the hydronic dream1 -
I think i've seen the top assembly on supplyhouse.com although it was named in a way that made it hard to find.hot_rod said:I’d be quite impressed if you can dis and reassemble the valve mechanism on that air purger. Here is a common fix😁. Or buy another and swap the top part.
I don't know if this is the right cap for yours:
https://www.supplyhouse.com/Spirotherm-PJR000HA-Vent-Head-for-Jr-Series-Air-Eliminators1 -
buy a whole new one most times the screen inside is corroding unscrew the top and change the screen and screw new top on. make sure its not under pressure0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 71 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
