Small leak
Hi I have a peerless boiler and I’m getting a small drip from this Anyone know what it is and how to remedy the problem
    EdTheHeaterMan Member Posts: 12,190
    edited November 2022
    That is an air vent. ...and not just any air vent. It is a micro bubble air vent. I have not had much success with taking them apart to repair the float valve inside them.
    Those threads on the end are 1/2" pipe thread. As a temporary fix you can add a 1/2" coupling with thread sealant (like teflon tape or pipe dope) then place a 1/2" close nipple and a 1/2" pipe cap on the threaded end to seal it until the off season. Then you can get a professional to come and repair or replace it.
  • Mike_reichert
    Mike_reichert Member Posts: 2
    is there a way to get it to stop dripping
    Take it apart and get the valve inside there cleaned out. But I would wait until the spring. just put the cap on it for now.
    hot_rod Member Posts: 27,471
    I’d be quite impressed if you can dis and reassemble the valve mechanism on that air purger. Here is a common fix😁. Or buy another and swap the top part.
    mattmia2 Member Posts: 16,814
    I think i've seen the top assembly on supplyhouse.com although it was named in a way that made it hard to find.
  • mikedo
    mikedo Member Posts: 301
    buy a whole new one most times the screen inside is corroding unscrew the top and change the screen and screw new top on. make sure its not under pressure
