Cycling Riello BF5 on a Buderus boiler
jenny2022
Member Posts: 2
in Oil Heating
I have new house so many details not known. Furnace not used for some time 2015? Installed 2007-ish. I have: cleaned boiler inside, replaced filter from outside tank. Burner repeatedly cycles on/off. Presume ran just fine at some time. Outside, exhaust runs clean (when firing) then smokes. Service not available for 6 weeks. Any thoughts?
Thanks for the comments. I live in downeast Maine and all the contractors nearby are flat out. But I will try the link and see what it says.0
Find a contractor link is still the best option. A 2nd best is who do you buy your oil from, they should know someone or better yet have their own service department.0
The settings and maintenance on that Riello are different than the more common Beckett burner. Make sure you get someone who’s qualified to work on it.
It probably needs maintenance and a combustion analysis.Bob Boan
is this a boiler? hot water / steam ?
or a furnace? hot air?
if a boiler, is it steam?
is the smoke a white plume ?known to beat dead horses0 -
My father and his brothers were in the oil business. If a customer's oil burner did not work... they sold less oil! The oil company will find a way to get the burner running!heathead said:Find a contractor link is still the best option. A 2nd best is who do you buy your oil from, they should know someone or better yet have their own service department.
White or black smoke ?
Black smoke = no PopeBig Ed_4 said:White or black smoke ?
White smoke = New Pope
But what does this have to do with the Riello Burner?
I'm sure there were some that do this practice, The F.P. Young Co. was not one of those. When I was in training, we were taught how to make the oil burner operate as clean and efficient as possible. Customers were paying big bucks to convert to natural gas back then. If that happened, no one would ever sell that customer a drop of oil ever again.STEVEusaPA said:
At less than 1/2 the cost of a new gas boiler, The company could "Modernize" your old heater with a new combustion chamber, barometric draft control, modern Honeywell round thermostat, accurate limit and safety controls, and a high efficiency Flame Retention oil burner. Your oil usage could drop from 10% to 50% or more.
The customers with new modern oil burners were still burning oil. Less oil is better than No oil. Customers were happy with the results and stayed customers for 10+ more years.
Based on @MikeAmann statement, I think if he were operating an oil company, I might purchase my oil elsewhere.
2
