Contractor toilet woes
1950sGem
Member Posts: 8
Hoping I can learn some wisdom here. And bounce a solution I came up with off some more knowledge folks to learn if it’s viable. We live in a 1950s Cape Cod with full house Base Ray radiators in every room and the basement. Our main bathroom is mostly original Crane fixtures and tiled walls. Sometime in the 80s they installed a new blue toilet and had the tiles finished white. We do not want to remodel this bathroom because it’s still really nice and would be a beast to demo. And we like it. A few weeks ago the tank on our blue toilet cracked. With tears in our eyes we decided it was time for a new camode. We ordered it and found a contractor that agreed to install it when it arrived. Upon install it appeared that we were about 1/4” too big to fit with the new toilet so this guy was like, “no problem I’ll just grab my metal hand wheel and shave a little off your radiator”. Is everyone cringing yet? He fires the saw up and seconds later I hear, “oh ****!” And gushing water coming from the bathroom. Are you crying for us yet?
Yes, this clingon with all his infinite wisdom failed to measure our toilet’s rough in and as a fix, sawed a pin size hole into our cast iron radiator. The entire system emptied through that hole. Like the little Dutch boy with his finger holding the dam. We shut everything thing off and he patched the hole with J&P Epoxy. I’ve attached pictures of: the patched hole and the bigger radiator line at large. The bleed valve is at the far left of the line.
So far it’s holding and we’ve had our system on for the last week.
As I was bleeding all the valves today to make sure there wasn’t air in the system I had an idea and forgive me if it’s a dumb one which is why I’m here. Could a skilled contractor who knows radiators install an extra bleeder valve where the hole was made as a more permanent fix?
Thank you for this validation Jamie. When you say ‘plug’ is there a certain radiator type of plug you’re referring to?Jamie Hall said:Yes. Or even drill it out and install a plug. Do NOT let the party with the grinder anywhere near the job.0 -
It's not directly related to your original question, but I'm way to curious not to ask.
How was the plumber planning on installing the new toilet considering the tiles went around the old one? The likelihood the new one will match that is slim to none from my experience. Also that is quite improper to have a toilet like that. If the flange ever leaked, you might not know it until the toiler fell through the floor. I see evidence of caulk which makes that even worse, never supposed to caulk around a toilet base in a residential application.
I'm guessing your crack plumber mentioned none of this?0 -
Thanks Matt, this unfortunately isn’t an option tho because to remove the radiator would start a domino effect of demoing the whole room which we DO NOT want to do0
My next question is how do I find a skilled contractor that knows these types of systems? Are there certain certificates or accreditations I look for? I don’t think I would even trust the place we use to do our seasonal tune ups at this point0
I patched a small hole in a hot water heating system with a 1/8 npt pipe plug. This requires drilling the hole to the correct size, tapping the hole with a thread tap, then coat the plug with Loctite and screw it in. Don't make it gorilla tight, the Loctite will seal it. Most hardware stores will have the plug, tap, drill bit, and Loctite.
2 -
Honestly he was going to stack 2 wax rings I think 😬. Wouldn’t that work? And that’s not actually caulk, it’s cement. I know it’s bad, but there’s a bathroom right underneath it and we haven’t noticed any leakage. SMH welp I’m glad I’m getting some honest feedback!KC_Jones said:It's not directly related to your original question, but I'm way to curious not to ask. How was the plumber planning on installing the new toilet considering the tiles went around the old one? The likelihood the new one will match that is slim to none from my experience. Also that is quite improper to have a toilet like that. If the flange ever leaked, you might not know it until the toiler fell through the floor. I see evidence of caulk which makes that even worse, never supposed to caulk around a toilet base in a residential application. I'm guessing your crack plumber mentioned none of this?0 -
It’s a hole. And it’s a 3 story. The slash cut looks bigger than the actual hole. I’ve attached a pic from before the epoxy.
hot_rod said:Is it a hold or a longer grind mark? If it is a long gouge, the JB weld may be the option to try. Run the system at as low as pressure as possible. If it is a single story 6-8 psi.0 -
Does the contractor have insurance? The proper fix is to install a new Base Ray radiator. A temporary hold that lasts 3 years ...and when if fails, where will the contractor be? I'm wondering where the pin hole actually is? If it is too close to the edge, you will need to make the hole on a 45° into the corner edge. I'm not sure that will hold up. What do you think @Jamie Hall?
on the top like the picture on the left will work no problem. On the corner, will there be enough thread to seal on both the sides and the top and bottom as the profile illustration shows? Maybe. Maybe not. Get the full repair done while there is a contractor on the hook.
And by the way, that looks like a Weil McLain product. Burnham has a rounded edge at that location.Edward Young Retired
I think that is just screwed to the surface of the wall, but it could take some creativity to disconnect and reconnect the piping without access from below.0
Now that I see the before picture, I would NOT attempt to drill and tap that. I had a flat surface to work with for my repair. Is there a way to cut off the water to just that radiator? If you had a valve for that, you would still have heat in the rest of the house if the patch failed. I think the current patch might be the best of a bad bunch of options. Two other options are to solder or braze a nail into the hole. I'm not sure that would be any better than the current epoxy patch.
2 -
If you could tile under the new WC, that might raise the tank to clear the heater.
There are extension rings to correct the height issue.
It should end up with the bottom of the top ring sitting as if it were on top of the tile.
There might be a creative way to cut the tile and fill in to make it look like a border around the WC.
So it would appear as part of the plan.
I would go for the contractor's insurance to replace it, hopefully he has some.2 -
WMno, thanks. Maybe installing an emergency kill valve for this area of radiator is a great solution should the epoxy fail down the line. We have an unfinished basement with exposed ceiling so finding that pipe might not be the most difficult.And thank you everyone for your input 🙏🏼 All of this has been beyond helpful and given us some…?peace? If that’s possible.Knowledge is power. Wish us all the radiator heating luck you can 🍀0
Remove the radiation and install something new. If the radiation doesn't fit the tile opening you can infill where there is no tile with 1/4 Plywood and bring the new radiation up to cover the joint.
All you need is a plumber or a heating guy that has a brain and can be a little creative.
If you don't fix it right you will have more issues down the road5 -
O.O0
Is there somethin more than an empty paper bag there to keep sewer gas from leaking into the house?
If it was mine, I'd be gutting it and starting fresh. It sucks, but sometimes the only choices you have suck. There's absolutely no way I'd leave a pressurized radiator patched with JB weld in my house though.
Until today I didn't even know painting tile and grout was a thing.
Is it a thing?
I don't know what options there are for radiation, but I'd want something high mass to match the rest of the house. It doesn't have to match cosmetically, but I'd want it close in behavior.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
You can take the end caps off that baseboard, looks like there are screws, cut away the grout on the new tiles with a grout saw or something. I think that is just screwed to the tile on the surface and caulked, but some digging in the caulk would confirm. Be careful to cut the caulk so you don't pull the tiles off with the baseboard.1
That's what I thought. Often times you will see toilets caulked around the entire base except for a few inches in the back with the idea that if there is a leak it will be noticed. That or people don't do back there because it is a pita.MikeL_2 said:I've been grouting, caulking / sealing plumbing fixtures for almost 50 years. Both the IRC & IPC require plumbing fixtures to be sealed water tight where they come in contact with walls & floors.......0 -
The way I would salvage the baseboard is to make a 90 deg angle patch that would fit over the cut, out of stainless steel. The patch would be larger than the cut area. I would rough up the baseboard that the patch would fit over and the underside of the stainless 90 deg angle and glue the patch over the cut with JB Weld. Walla, done. Then sell the house!
I would grind the white JB weld off and do as I suggested. JB Weld is gray not white as it has steel particles in it.
Lol the paper bag was so the cat didn’t try and go down the hole. It has the wax rings in itChrisJ said:Is there somethin more than an empty paper bag there to keep sewer gas from leaking into the house? If it was mine, I'd be gutting it and starting fresh. It sucks, but sometimes the only choices you have suck. There's absolutely no way I'd leave a pressurized radiator patched with JB weld in my house though. Until today I didn't even know painting tile and grout was a thing. Is it a thing? I don't know what options there are for radiation, but I'd want something high mass to match the rest of the house. It doesn't have to match cosmetically, but I'd want it close in behavior.0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
