circulation pump flow direction
beloitmtshop
Member Posts: 7
how can i change direction of flow without turning the circulation pump upside down. I have replaced a B&G 37s but the arrow on the volute is in the wrong direction.
Why?beloitmtshop said:how can i change direction of flow without turning the circulation pump upside down
Arrow on the volute is opposite of the old one, pipes bang when zone valves shut off0
If I understand your question, you have no choice. The veloute must be turned 180 degrees. I find that most people leave the old veloute and swap everything else (gasket, bearing assembly, coupler and motor).0
If it in backwards then the Flow Check should stop all flow.beloitmtshop said:Arrow on the volute is opposite of the old one, pipes bang when zone valves shut off
Can we get some pictures of what you have?0 -
I'm guessing there are no flow checks if there are zone valves. Is it possible that the new pump flow direction is correct and the high head is causing issues with the zone valves trying to open and close? Keep in mind that a PD37 tops out around thirty feet of head, most zone valves would struggle to function correctly with that much head pressure. Maybe consider a pressure bypass valve?
I agree, photos or at least a sketch would help.0 -
would removing the gasket, bearing assembly, coupling and motor then rotating the volute 180 degrees and reattaching the gasket, bearing assembly coupling and motor change the flow then.0
@beloitmtshop
no. you have to turn the volute to make the arrow go the right way and the turn the motor so it is mounted correctly0 -
there are no flow checks, very old boiler. So simply turning the volute 180 degrees would not reverse the flow?0
How did this volute get reversed in the 1st place?0
In simple terms, if the arrow on the veloute points towards the floor now and you remove the eight flange bolts and flip the veloute upside down, so the arrow points towards the sky, yes the flow will go in opposite direction. Don't forget to rotate the motor and bearing assembly as well.0
it came from the factory with the arrow pointing the wrong way0
I know the idea of reversing the motor's direction of rotation was not proposed - but even that wouldn't help. A centrifugal pump sends water in the same direction whether the motor runs, say, clockwise or CCW - although less efficiently.0
Your supposed to flip the components to match the direction of flow. Bell & Gossett has no way of knowing if your pump is pumping upwards, downwards or sideways.0
but the motor has oil cups, turning the motor upside down will allow oil to leak out.0
I highly doubt that.beloitmtshop said:it came from the factory with the arrow pointing the wrong way
So you changed the entire pump?0 -
Why didn't you just get a Taco circulator.beloitmtshop said:but the motor has oil cups, turning the motor upside down will allow oil to leak out.
yes, changed the volute and pump all at once, the arrow on the new volute pointing down instead of up on the new unit.0
Please post a picture of the B+G circulator and the installation; circulators with oil cups for lubrication of the electric motor bearings can only be mounted vertically.0
As @ScottSecor mentioned, a repair guy would typically just switch the motor/ bearing assembly, leave the old volute in place. No need to mess with flange gaskets. And the arrow stays correct
Keep in mind those circs get installed in horizontal lines also, so you need to confirm the installation mounting requirement.Bob "hot rod" Rohr
Living the hydronic dream0
- 117 Geothermal
