Steam air vent
mmc239
Member Posts: 94
I am going to Home Depot to buy made o mist air vent for my steam baseboard located directly above my boiler. Which model should I get?
That depends entirely on how big that baseboard is, and more importantly on how well it heats the space. So I can't really answer that...Br. Jamie, osb
The air vent I have there now is Varivalve and it spits water out of it when I first turn heat on. It is brand new vent.0
we see the vent end supported, and fixed at the valve end,
any chance that length of fin tub is sagging in its middle?
can you get a eyeball on that ?
and it all pitches back to the valve?
and then you want the slowest vent in the world on that end.known to beat dead horses0 -
Which letter or number vent is the slowest?0
you've found my weakness, IDK,mmc239 said:Which letter or number vent is the slowest?
there's another thread running with a link to charts here,
I'll look for that thread, you can try search function here also,
"steam venting charts"known to beat dead horses0 -
https://heatinghelp.com/assets/documents/Balancing-Steam-Systems-Using-a-Vent-Capacity-Chart-1.pdf
it's in the middle back where the charts startknown to beat dead horses0 -
That vearivalve is a notoriously fast vent, even when closed. A slow vent would be something like a Hoffman 40. Gorton also has slower vents, as does Maidomist which makes them with replaceable orifices so you can adjust them.—
Bburd0 -
After reading up, I have decided to use a Gorton air vent. I just don’t know if I should use a #4 or 5. This is a steam baseboard located in my living room. The thermostat is in the kitchen about 12 feet away.0
Slowest would be the driest
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
