Steam air vent
mmc239
mmc239 Member Posts: 94
I am going to Home Depot to buy made o mist air vent for my steam baseboard located directly above my boiler. Which model should I get?
    Jamie Hall Member Posts: 27,604
    That depends entirely on how big that baseboard is, and more importantly on how well it heats the space. So I can't really answer that...
  • mmc239
    The air vent I have there now is Varivalve and it spits water out of it when I first turn heat on. It is brand new vent.
  • neilc
    neilc Member Posts: 3,201
    we see the vent end supported, and fixed at the valve end,
    any chance that length of fin tub is sagging in its middle?
    can you get a eyeball on that ?
    and it all pitches back to the valve?
    and then you want the slowest vent in the world on that end.
    known to beat dead horses
  • mmc239
    Which letter or number vent is the slowest?
  • neilc
    edited November 2022
    you've found my weakness, IDK,
    there's another thread running with a link to charts here,
    I'll look for that thread, you can try search function here also,
    "steam venting charts"
  • neilc
  • bburd
    bburd Member Posts: 1,320
    That vearivalve is a notoriously fast vent, even when closed. A slow vent would be something like a Hoffman 40. Gorton also has slower vents, as does Maidomist which makes them with replaceable orifices so you can adjust them.
    Bburd
  • mmc239
    After reading up, I have decided to use a Gorton air vent. I just don’t know if I should use a #4 or 5. This is a steam baseboard located in my living room. The thermostat is in the kitchen about 12 feet away.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,553
    Slowest would be the driest
