Can you identify these IBC parts
ChrisWilliams2
Member Posts: 31
I found these parts inside the IBC boiler housing, I am sad to see that I think the white one is the external temperature sensor, which I believe can easily be added and if it does the same outdoor set function as my Beckett Aquasmart should help with cost savings? Do you know what the other 2 parts are? Thank you
Spoke with IBC, that is the outdoor reset, I installed it ran it outside and wired it in and IBC walked me through the install. This really concerns me though about the whole install. I feel like if they skipped this, what else is wrong.0
@ChrisWilliams2
Many installers are scared of using outdoor reset. They don't want to figure out what the correct settings should be, and they don't want call backs. I am not sure why there is an extra condensate fitting, the orifice is likely the unused one for whichever type of gas you are not using. While I like to see the outdoor reset technology used, I would not say that these parts are a red flag at all. In fact it's good they left them there in case you want to use them, or may need them later0 -
This is all good to know thank you guys!0
You should have been made aware that the OD wasn't installed by the contractor when it was commissioned. It's sad that many contractors aren't up to speed on OD because it requires some careful reading. All HW boilers work more efficiently with it and fuel savings can reach 30-40% than by not using it. Once the heating curve is correctly set, the boiler will remember what to do automatically to reach the setpoint temperature. It often takes an adjustment to get it where you want it and the house is comfortable
1
- 117 Geothermal
