Better alternatives to Nest
zvalve
Member Posts: 83
I have a rental unit in my house and thought a smart thermostat would be a good option since I don’t have to put an intimidating lock box around the thermostat. I can get a Wi-Fi thermostat at substantial savings from National Grid LI NY. I have a gas fired boiler with hydronic heating two zones, one for the rental unit. Are there better alternatives to a Nest? What does the community think?
I like and have had good luck with Ecobee. Easy to install and understand.Bob "hot rod" Rohr
Prity much everything is better than NEST!
Honeywell makes controls that you can set high / low limits and are WiFi
Im hearing good things about WYZE, they are trying to be an affordable option to replace ring door bells and nests. Havent used them myself, but have customers who have
Tom
Montpelier Vt0 -
Love our Ecobee. Very customizable but also easy to use.0
