Lots of white smoke from neighbor's chimney
meofbillions
Member Posts: 2
No other chimney in the neighborhood belches such smoke, which is probably condensed water, because it vanishes. But I'm wondering if there's a problem with their heating system, for instance: with a water-based system, there could be a hole in the heat exchanger, spurting water into the combustion chamber, causing steam? This is the second year now that I notice this about that chimney, every morning when the weather is cool.
Most likely.Br. Jamie, osb
is it oil or gas? Gas will look like white smoke when it is cold outside as the flue gas condenses.0
I get some white smoke when it's really cold out. Near or below 10FEBEBRATT-Ed said:is it oil or gas? Gas will look like white smoke when it is cold outside as the flue gas condenses.
I don't think I notice it if it's in the 20s out though.
Why would fuel type matter? A water leak into any combustion chamber would produce steam.EBEBRATT-Ed said:is it oil or gas? Gas will look like white smoke when it is cold outside as the flue gas condenses.
Gas fired systems produce visible water vapor in the exhaust whenever it’s very cold outside. Oil fired systems don’t, or at least not until it’s a great deal colder, unless there is an internal leak in a steam boiler above the waterline. The difference is due to the much higher hydrogen content of gas, which produces more water vapor in the products of combustion.—
Bburd0 -
If it's a steam system, the boiler probably has a leak above the waterline.All Steamed Up, Inc.
Consulting0 -
Could it be a condensing boiler or furnace using the chimney as a chase?0
@meofbillions, is your neighbor even aware?0
Quite true that a gas fired boiler or furnace will produce some white smoke -- but not a lot of it. If it's lots of white smoke, it's a leak.Br. Jamie, osb
- 116 Geothermal
- 15.8K Strictly Steam
