steam boiler drop header
Paul S_3
Member Posts: 1,294
New 75k 196 sq ft steam boiler installed today 10 hour day...vxt-24 auto feeder...vaporstat....4 Gorton #2's....3 inch drop header...2 1/2 supply valve....still have to go back to skim boiler etc.
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
347-692-4777
ASMHVACNYC.COM
6
Nice Job !!
drpepper-1 -
Good job!
Will you put a good low pressure gauge on to keep the vaporstat honest?--NBC0 -
Piping looks good, but where's your drip leg on that gas line?
Yes...i would love too...but i can't find any in supply houses....yes i have to extend drip leg....i guess my partner installed cap on close nippleASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
http://www.amazon.com/Dwyer®-Pressure-LPG4-D9122N-Connection-8-0-16/dp/B00E6GEA7SPaul S said:Yes...i would love too...but i can't find any in supply houses....yes i have to extend drip leg....i guess my partner installed cap on close nipple
http://www.cappusa.com/dwyer-lpg4-d9122n
Dwyer LPG4-D9122N does -8" to + 16". Both of the pictures shown at the stores above are wrong.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Thank you ChrisASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
Purty job!!! Never heard of that boiler, small company? What are the round brown things above the piping? Vents?0
Beautiful Job!0
Yes gorton 2 main vents....union steam is made by weil mclain....or williamson....i couldnt find a supplier with a 75 k steam boiler in stock.....until i found the supplier with this boiler....most said its too small to carry...this was a emergency job they needed the heatASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
Nice job. FYI, Williamson does not allow the return to be connected to the right side of the boiler. They want the return to be on the same side as the controls. Personally, I don't think that makes any sense. I also think that they do not allow you to use the right hand supply tapping. Same reason. Don't mean to criticize at all . I use the right and left hand tapping all the time. Just thought that you might want to know0
Thank you....thats wierd about the supply and return tappimgs thoughASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
My EG-40 is plumbed the same way as your boiler, with the return in the rear, as I call it, opposite of the gauge glass and I'm using both supplies.
This job should go on the Drop Header photo page, it's that good.All Steamed Up, Inc.
Consulting0 -
Thank you Steamhead....ASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
@Paul S .Agreed. Very weird. If anything, would make more sense to have supply on opposite side as LWCO0
Thank you EzzyASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
Ditto on the hall of fame comments. You get my vote0
We tried our best.Qasim mohmood
Asm mechanical Company
152 watchogue rd
staten island ny 10314
Asmmechanicalcorp@gmail.com
Asmhvacnyc.com
347-692-47770 -
Counter-flow?0
No parallel flow with gravity return with dry returns ....i guess they dripped the beginning of the main because its kinda back pitched...really dont know why it was doneASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
Nice job. What's the small pipe for next to the take off?0
- 50 Industry Classes
