steam boiler drop header
Paul S_3
Paul S_3 Member Posts: 1,261
New 75k 196 sq ft steam boiler installed today 10 hour day...vxt-24 auto feeder...vaporstat....4 Gorton #2's....3 inch drop header...2 1/2 supply valve....still have to go back to skim boiler etc.
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
lchmbSWEIkcoppQasimMohmoodPC7060EdTheHeaterMan
  • David Sutton_6
    David Sutton_6 Member Posts: 1,079
    Nice Job !!
    drpepper
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,576
    Good job!
    Will you put a good low pressure gauge on to keep the vaporstat honest?--NBC
  • ChrisJ
    ChrisJ Member Posts: 15,706
    Piping looks good, but where's your drip leg on that gas line?
    Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment
  • Paul S_3
    edited April 2016
    Yes...i would love too...but i can't find any in supply houses....yes i have to extend drip leg....i guess my partner installed cap on close nipple
    347-692-4777
    ASMHVACNYC.COM
  • ChrisJ
    http://www.amazon.com/Dwyer®-Pressure-LPG4-D9122N-Connection-8-0-16/dp/B00E6GEA7S
    http://www.cappusa.com/dwyer-lpg4-d9122n
    Dwyer LPG4-D9122N does -8" to + 16". Both of the pictures shown at the stores above are wrong.
  • Paul S_3
    Thank you Chris
    347-692-4777
    ASMHVACNYC.COM
  • John Mills_5
    John Mills_5 Member Posts: 951
    Purty job!!! Never heard of that boiler, small company? What are the round brown things above the piping? Vents?
  • Fred
    Fred Member Posts: 8,542
    Beautiful Job!
  • Paul S_3
    Yes gorton 2 main vents....union steam is made by weil mclain....or williamson....i couldnt find a supplier with a 75 k steam boiler in stock.....until i found the supplier with this boiler....most said its too small to carry...this was a emergency job they needed the heat
    347-692-4777
    ASMHVACNYC.COM
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 1,973
    edited April 2016
    Nice job. FYI, Williamson does not allow the return to be connected to the right side of the boiler. They want the return to be on the same side as the controls. Personally, I don't think that makes any sense. I also think that they do not allow you to use the right hand supply tapping. Same reason. Don't mean to criticize at all . I use the right and left hand tapping all the time. Just thought that you might want to know
  • Paul S_3
    edited April 2016
    Thank you....thats wierd about the supply and return tappimgs though
    347-692-4777
    ASMHVACNYC.COM
  • ChrisJ
    My EG-40 is plumbed the same way as your boiler, with the return in the rear, as I call it, opposite of the gauge glass and I'm using both supplies.
    Steamhead Member Posts: 16,843
    This job should go on the Drop Header photo page, it's that good.
    Consulting
  • Paul S_3
    Thank you Steamhead....
    347-692-4777
    ASMHVACNYC.COM
  • EzzyT
    EzzyT Member Posts: 1,295
    Beautiful piping job Paul
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
  • STEAM DOCTOR
    @Paul S .Agreed. Very weird. If anything, would make more sense to have supply on opposite side as LWCO
  • Paul S_3
    Thank you Ezzy
    347-692-4777
    ASMHVACNYC.COM
  • STEAM DOCTOR
    Ditto on the hall of fame comments. You get my vote
  • JUGHNE
    JUGHNE Member Posts: 11,062
    A great example that the NBP is part of the steam boiler!
    I would almost envision more volume in the piping than the steam chest of the boiler.
    QasimMohmood
  • QasimMohmood
    QasimMohmood Member Posts: 4
    We tried our best.
    Qasim mohmood
    Asm mechanical Company
    152 watchogue rd
    staten island ny 10314
    Asmmechanicalcorp@gmail.com
    Asmhvacnyc.com
    347-692-4777
  • Paul48
    Paul48 Member Posts: 4,469
    Counter-flow?
  • Paul S_3
    edited April 2016
    No parallel flow with gravity return with dry returns ....i guess they dripped the beginning of the main because its kinda back pitched...really dont know why it was done
    347-692-4777
    ASMHVACNYC.COM
  • ranzerox
    ranzerox Member Posts: 52
    Nice job. What's the small pipe for next to the take off?
    EBEBRATT-Ed Member Posts: 15,543
    @ranzerox 6 year old thread
    ranzerox
