Vent Corrosion
Member Posts: 4,694
I see this so often on plumbing vents, always in the kitchen. The deterioration is from the inside, out and the pipe is filled with the sloughed off material.
Does anyone know why this happens? Electrolysis?
This is a bit of a WAG, but I'd think it was because the inside of that vent is always wet or perhaps better said damp, with just enough air flow for a continuous supply of oxygen, and likely with some interesting acids in the "air" as well. Not a friendly environment.Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England1
- 117 Geothermal
