Vent Corrosion
Alan (California Radiant) Forbes Member Posts: 4,828
edited September 2022 in THE MAIN WALL
I see this so often on plumbing vents, always in the kitchen. The deterioration is from the inside, out and the pipe is filled with the sloughed off material.
Does anyone know why this happens? Electrolysis?
    Jamie Hall Member Posts: 27,637
    This is a bit of a WAG, but I'd think it was because the inside of that vent is always wet or perhaps better said damp, with just enough air flow for a continuous supply of oxygen, and likely with some interesting acids in the "air" as well. Not a friendly environment.
