Water heater nipple removal
rich p_4
Member Posts: 25
Hello,
Does anyone have a tool or a good and easy way to remove corroded nipples from the top of water heaters.
I have tried many ways but it always is a difficult and nerve racking job, with uncertain outcome.
thanks
Rich
thanks
Rich
There are various types of inside pipe wrench. That probably wouldn't work with plastic lined nipples.-1
I have tried that once
I have also used a 3/8" socket extension tool
also wooden dowels.
I still have not had a proven simple effective way.....
Thanks0 -
Hi, My approach is to insert a steel rod into the nipple so it can't collapse. Then use as big a wrench as needed to encourage the nipple to come loose. This prevents the nipple from tearing off. Here's a photo of the simple tool I made for doing this. It's 3/4" in diameter. It's worked nicely for years.
Yours, Larry10 -
Also works with a drill bit and brake bleeder screws.0
Thank you all for the positive and creative ways of giving it a go.
I have used a large handle ratchet strap around the tank to give me something to grab and hold onto.
Never sieze is a great idea. I have never pulled the nipples out on a new tank. Of course this might just be the answer for the future (or even just some teflon tape)
Thanks Again,
Rich0 -
Teflon with never seize on it0
if if it is plastic lined I would drive one of these square easy outs into the nipple
Then use a cordless impact wrench so you don’t have to hold the tank tightly, not an easy task😟Bob "hot rod" Rohr
Living the hydronic dream0
- 116 Geothermal
- 15.8K Strictly Steam
