Water heater nipple removal
rich p_4
rich p_4 Member Posts: 25
Hello,
Does anyone have a tool or a good and easy way to remove corroded nipples from the top of water heaters.
I have tried many ways but it always is a difficult and nerve racking job, with uncertain outcome.
thanks
Rich
    mattmia2 Member Posts: 17,199
    There are various types of inside pipe wrench. That probably wouldn't work with plastic lined nipples.
  • rich p_4
    I have tried that once
    I have also used a 3/8" socket extension tool
    also wooden dowels.
    I still have not had a proven simple effective way.....
    Also works with a drill bit and brake bleeder screws.
    pecmsg Member Posts: 7,180
    They make reverse drill bits for that purpose.
    Removing when new and never seize saves trouble later!
    MikeAmann
  • rich p_4
    Thank you all for the positive and creative ways of giving it a go.
    I have used a large handle ratchet strap around the tank to give me something to grab and hold onto.
    Never sieze is a great idea. I have never pulled the nipples out on a new tank. Of course this might just be the answer for the future (or even just some teflon tape)
    Thanks Again,
    Rich
    EBEBRATT-Ed Member Posts: 20,383
    Teflon with never seize on it
    hot_rod Member Posts: 27,701
    if if it is plastic lined I would drive one of these square easy outs into the nipple
    Then use a cordless impact wrench so you don’t have to hold the tank tightly, not an easy task😟
