Help! What kind of heat do I have and how do I make it stop??
horseshapedfire
Member Posts: 4
I live in an apartment building and it is constantly 100 degrees in here during the fall and winter because I have no control of the heat. There’s no thermostat in my apartment. I hate having to open my window because I live right next to a train station and it’s always loud. How do I make it so the heat doesn’t come up or is at least decreased?
I also have no ability to turn the knob on any of the radiators in the apartment. I think they are soldered open.0
It's two-pipe steam. If the management doesn't care, maybe cover the front of that convector with an insulating blanket.All Steamed Up, Inc.
Consulting1 -
If you know a handy man with sheet metal or you are a DIY, a damper control like this is easy and simple to make on your existing radiator. Then this is a permanent fix on that convector.
2 -
Thank you so much everyone! We wrapped the finned heating element in heavy duty aluminum foil, hopefully that does the trick.0
- 50 Industry Classes
