Help! What kind of heat do I have and how do I make it stop??
I live in an apartment building and it is constantly 100 degrees in here during the fall and winter because I have no control of the heat. There’s no thermostat in my apartment. I hate having to open my window because I live right next to a train station and it’s always loud. How do I make it so the heat doesn’t come up or is at least decreased?
  • I also have no ability to turn the knob on any of the radiators in the apartment. I think they are soldered open.
    Steamhead Member Posts: 18,393
    It's two-pipe steam. If the management doesn't care, maybe cover the front of that convector with an insulating blanket.
    Consulting
    horseshapedfire
    pecmsg Member Posts: 7,013
    Opening a window ga small amount is NOT a bad thing. Fresh air is required.
    As said cover the top of the coil with a towel, blanket anything WILL reduce the amount of heat emitted!
    horseshapedfire
    mattmia2 Member Posts: 16,384
    Is that valve one of those american radiator valves with the screw under the cap that adjusts how much steam it lets in?
    horseshapedfire
    EBEBRATT-Ed Member Posts: 20,056
    Agree with @bburd the tin foil trick is cheap and easy. try that first
    EdTheHeaterManhorseshapedfire
  • jerryb46
    jerryb46 Member Posts: 60
    Stay away from the valve!!,could cause more problems follow the advice from above.
    EdTheHeaterMan Member Posts: 11,989
    edited September 2022
    If you know a handy man with sheet metal or you are a DIY, a damper control like this is easy and simple to make on your existing radiator. Then this is a permanent fix on that convector.
    horseshapedfireSteamFTW
  • Thank you so much everyone! We wrapped the finned heating element in heavy duty aluminum foil, hopefully that does the trick.
