NYC Permit for Boiler Replacement
rosaliedipietro2
Member Posts: 26
Is a permit required in NYC if a homeowner is replacing an existing boiler and water heater in the same location where it is currently?
A Master Plumber recommended it However, it costs $2500 for the permit.
I currently have a hot water boiler and a separate water heater. Am looking to install the Navien combi boiler.
Any insight or resources regarding whether a permit is required?
Thanks!
Thanks!
As I read the regulations, you are not an in-kind replacement, so I'd say yes you need the permit. Some of the folks who work in New York City may comment.Br. Jamie, osb
seems Pricy! Glad I don't live in NYC
You need a permit to replace a gas boiler of any kind in NYC. There are basically two levels of permit: OP-128 and LAA. The "LAA" is the higher level of filing which is for moving or reconfiguring gas piping or in buildings with 6 or more units. That is a simplified explanation but it probably covers your purposes. If your installation does not require significant gas pipe reconfiguration then your OP-128 (Ordinary Plumbing-128) should cost a few hundred bucks. But then again, there are some variables.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0
- 120 Geothermal
