Radiator
Are the pipe radiators in the bathrooms that smell only the one at the top with the vent or is it lower apartments too?
Did someone already link to the story about the super that was pissing in the boiler?0 -
GGross said:tbh I read through all this and I'm still a bit confused. Did the apartment ever smell good? How the heck has your brain not just forced the smell to not register? (like a smoker can't smell their own smoke) Any chance you could just scam a friend into switching apartments with you so you can get out of there? Years! Years and it stinks the whole time, I couldn't do it. Also I would like to thank you for updating after all this time, it's quite the read but I feel like it should go on a "Best of the Wall" or something. Maybe if there is ever a conclusion it will be honored as such.
Lol it only stinks when that one radiator comes on so it stays off or I'd die.0 -
Dunno there is only one pipe in all the bathrooms in the building it goes from ceiling to floor mine doesn't smell but a neighbors does and her radiator. Others it's just radiators or a combo so far I know 7 apts got issues. And they all randomly located apart from each other.mattmia2 said:Are the pipe radiators in the bathrooms that smell only the one at the top with the vent or is it lower apartments too? Did someone already link to the story about the super that was pissing in the boiler?0 -
Hello, I haven't re-read the whole thread, but don't remember if testing for the odor was ever mentioned. I find this place: https://indoorscience.com/what-we-do/indoor-air-quality/odor/ and there are probably others that might be able to figure out just what the odor is. Knowing that will go a long way towards being able to fix it.
Yours, Larry2 -
Considering no one knows if its a nuisance smell or if its possibly dangerous, it sounds like an indoor air quality test would be prudent. If it's an experienced person, they might have a good idea of what to verify via test as soon as they smell it. If the cost is an issue, perhaps contact the other tenants that have noticed the smell to see if they would like to split the cost and then you will share the results.Larry Weingarten said:... others that might be able to figure out just what the odor is. Knowing that will go a long way towards being able to fix it.
Currently in building maintenance.3 -
maybe a mouse crawl into the pipe when the reno was performed. they get anywhere0
- 167 Indoor-Air Quality
