Toilet next to steam radiator
I think I have several options:
- Replumb the lines under the room (in the crawlspace) so the toilet can be moved (mix of cast iron and PVC)
- Use an offset flange. But I'm not a fan as it may impede flushing and flushing/clogging is already an issue
- Try to move the radiator: maybe replacing the right-angle valve with an elbow, nipple, and in line valve will shift it away from the toilet. Possibly combine this with a new radiator that is taller but has fewer sections
- Reposition the flange and bolts so the toilet can be at a slight angle. Awkward?
Without really looking at the whole space... hard to say. If you have a mold problem, though, I hope you are taking up the floor while you are at it.
In which case I'd probably look at some combination of your first and third options. I agree that offset flanges can give trouble -- particularly with the low flush toilets, and the fourth option? Um... no, not really!Br. Jamie, osb
While you have it open, would it be reasonable to swap the toilet and vanity? Or are there clearance issues in front? The vanity doesn't care if it is 6" away from the radiator. You might be more concerned on the toilet.0
Might be possible, depends on the exact door swing, how big the new vanity is, etc.mattmia2 said:While you have it open, would it be reasonable to swap the toilet and vanity? Or are there clearance issues in front? The vanity doesn't care if it is 6" away from the radiator. You might be more concerned on the toilet.
Steaming along slowly in Wharton, Morris County, NJ.0 -
I know some of the subfloor under the tile must go as it's rotting. Not sure how much of the rest of the floor will go. Tile's a simple white with red center design so if it isn't entirely replaced, a similar pattern could be found to cover any new holes.Jamie Hall said:Without really looking at the whole space... hard to say. If you have a mold problem, though, I hope you are taking up the floor while you are at it.
The toilet will be replaced (cracked near the bolt holes), vanity replaced (internal mold damage from a leaking can of cleaner), along with the never-worked spa tub/shower stall (which is also too high for easy entry), and I imagine a lot of the plaster and maybe some studs as well.Steaming along slowly in Wharton, Morris County, NJ.0 -
Given all that, I'd start with a blank sheet and redesign the whole space. Don't try to fudge it -- around any of the plumbing or heating pipes. They can be moved to suit, and you will (or at least I would) be happier with a clean sheet redesign. If it turned out you didn't have to move something, so much the better.SteamedInWharton said:
The toilet will be replaced (cracked near the bolt holes), vanity replaced (internal mold damage from a leaking can of cleaner), along with the never-worked spa tub/shower stall (which is also too high for easy entry), and I imagine a lot of the plaster and maybe some studs as well.Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England4 -
I would draw the bathroom floor to scale. Then cut some paper with a scissors make one the size of the radiator, one the size of the vanity and one the size of the toilet. Put them on the scaled drawing and move them around until you like the layout.
It's probably easier to relocate the radiator than the other two.2 -
The plumbing code does have a defined space required for WC, 30” at one time, excepting accessibility installations. Is the radiator on an outside wall?Bob "hot rod" Rohr
Yes it's on an outside wall.hot_rod said:The plumbing code does have a defined space required for WC, 30” at one time, excepting accessibility installations. Is the radiator on an outside wall?
- 50 Industry Classes
