Maximum BTU/hr with 3/4-inch black pipe?
Steve Garson_2
Member Posts: 712
My 115K BTU gas boiler is fed with a 3/4-inch gas pipe. I would like to install an instantaneous gas water heater that will provide 4-GPM, but wonder if the gas pipe will support the two.
Will this work? Or will the load be too large for the pipe?
Steve from Denver, CO
Potentially you'll need to upgrade your gas service too. You should also check if these instantaneous units are banned in your area. They are causing problems because they use gas so quickly that the gas network can't keep up if too many of them are installed. They all turn on about the same time everyday in many areas( ie morning showers, etc.)To learn more about this professional, click here to visit their ad in Find A Contractor.2
- 50 Industry Classes
