Does anyone know what this urn-like thing is - sewer pipe in closet
steam2pipe
steam2pipe Member Posts: 59
The sewer pipe located in a basement hallway closet has a large hole (covered with black tarp right now) that needs repair. See attached photo. However, plumbers can't get under this slab of cement and a cast iron pipe covered with cement and connected to this urn-like thing/cement attached. I've attached a photo if anyone has clue. I wondered if it was an old 'pit latrine' serving residents that lived here in 1860 when the building was built. The pipe is very old and plumbers do not know how to remove the cement without breaking the cast iron pipe. Any and all suggestions are welcome because right now the broken pipe needs to be repaired asap.
photo:
  • steam2pipe
    PS Here is a photo of the other end of that sewer pipe covered with a tarp for now. The plumbers need to get at that end to replace with PVC.
  • pedmec
    pedmec Member Posts: 1,356
    looks to me like it might be a closet bend with some sort of plug in the opening. the vent for it is to the right.
    Jamie Hall Member Posts: 27,392
    master trap? With a cleanout opening on top.
    PC7060
  • HomerJSmith
    HomerJSmith Member Posts: 2,779
    edited July 2022
    Wild guess...a running drum trap or cleanout.
    mattmia2 Member Posts: 16,859
    I"m pretty sure some care with a chisel and hammer will take the concrete/mortar off without breaking the cast iron. Clay could be a a different story.
    reggi
  • steam2pipe
    Thanks, everyone, for your comments.
  • Intplm.
    Intplm. Member Posts: 3,030
    Might as well plan for the worst of it. It will probably break. It is also repairable so no need to be too concerned. It looks like an old cleanout exiting the building, or a clean-out serving a house trap.
    Perhaps it is a drain for something in the attic that comes out the eave and that is a trap.
