Cleaning Out Old Giant Boilers From The Inside?
D107
Member Posts: 1,944
Family lore has it that my grandfather, who worked as a maintenance man for one of NYC's skyscrapers (The Continental Building, 1450 Broadway) originally built in the early 1930s––was short enough––about 5'4"––to fit inside their boilers for cleaning when he worked there from the 1940s––60s. Is that possible? The building has almost 400,000 square feet. I'm assuming it had steam heat but not sure.
Yes, I can imagine it wasn’t fun. I recall cleaning the inside of a cement truck cylinder as a teenager in the 1970s using a hammer and chisel. Of course no hearing / eye protection was required or used. It was during the winter shut down at a prefab concrete place where I worked. It was either clean cement truck cylinders or not get paid.@JUGHNE - The company and location where I worked was the Gerhold company at the Columbus concrete redimix plant. Although not in heating (
), it was (and is) a well known Nebraska company formed 1869. 1 -
In my younger years working for CS&E of Pittsburgh, Pa. I climbed into the fire box of many boilers, both fire tube and water tube. We had a skinny kid that could even fit through the 11"x15" manway cover at the top of most firetube boilers. The first time I heard of a "confined space permit" my reaction was ???. At a later date I was thankful for the requirement.1
We used to have a pressure washer trailer with 6 cylinder diesel drive to clean energy boilers drums and tubes with 10,000 psi water. Cleaning was done from inside of the drums. But we are not doing it anymore. Sold power washer to the company in New Zealand.Gennady Tsakh
Absolute Mechanical Co. Inc.1 -
Followed up on @JakeCK information on confined space permits and found a 22 page safety procedure for cleaning of cement truck cylinders!
https://depts.washington.edu/silica/pdf/gatech.edu_chipout_files_docs_eng-manual.pdf
3 -
i guy got killed in the 70's cleaning out a large Trichlorothane storage tank a few towns away from me. His buddy got out and was found passed out half way out of that tank, no respirators and a ventilation jan had popped it's breaker.
Companies back then played fast and easy with safety, they were all for safety till it cost them money or time. There's was a shipyard a few miles from me where a crane operator was told to move a load from one ship building bay to the other. He told the boss he thought the load a bit heavy but was told to move the load or quit. The guy did as he was told and that crane and it's load plummeted 100 ft into a bay - they tried to pin it all on the dead guy.Smith G8-3 with EZ Gas @ 90,000 BTU, Single pipe steam
3PSI gauge1 -
Nice video...
https://www.youtube.com/watch?v=i442Y6TqHeg Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England3 -
Yes, common practice to enter and clean ships boilers at a thousand steaming hours, the Navy had gone to chemically cleaning watersides by the time I was in, but you removed all the drum internals and cleaned the fire sides with wire brushes.
Later I worked at a hospital that burned 6 oil fireside’s were VERY messy. We also manually cleaned the water side tubes. Sending a Goodway Tube router down 6 hundred tubes made for a long day.There was an error rendering this rich post.
- 87.2K THE MAIN WALL
- 119 Chimneys & Flues
- 164 Indoor-Air Quality
- 75 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.6K Strictly Steam
