time for a new ac - inverter or not
Try buying one or getting information.pecmsg said:
A google search brings a lot of hits!
Spacepac seems to have something ... the guy I know who does them was not any help (just for information)
Buying a one off from Europe is a good way to have an expensive paperweight in a few years ..0 -
Heat pump water heaters for domestic water are readily available.For heating I know of nothing to replace 180* fossil fuel. 140* is possible, is there a return on investment?0
Tag a few issues with Bosch BOVA but all fine- we’ve installed 40’or 50. Carrier Greenspeed- we installed 12 or 15- had to replace one compressor. I also have one older couple complaining about a BOVA outside their bedroom window (20 year old ac was in the same spot)
my comments were really more on the German car front- but I think there are some similarities. With an inverter system, once the warranty is up, repairs could really cost some dough- Possibly thousands of dollars0 -
My brother did two of the Bosch units when he moved to SC a couple years ago as a retrofit -- his existing condensers were in bad shape -- interesting units.GW said:Tag a few issues with Bosch BOVA but all fine- we’ve installed 40’or 50. Carrier Greenspeed- we installed 12 or 15- had to replace one compressor. I also have one older couple complaining about a BOVA outside their bedroom window (20 year old ac was in the same spot)
I did find the high pitch noise annoying with the Greenspeed .. don't know if they ever fixed it with the scroll compressor. The Carrier 5 speed is nearly silent -- I have to walk up to them to make sure they are running. Even in HP on top speed they don't make much noise ... nothing I can hear through a window.0 -
I’m taking the plunge on the Bryant Evolution inverter system. Serious overkill for sure but it’s getting hotter and more humid here in Minneapolis. Now I can say both my heating and cooling systems are modulating and condensing.
Thanks for all the input, I appreciate it. The installer has a good reputation and had all the right answers along with factory trained people.
GW - I totally get the German car comparison. I drove Audi for many years.
@Larry (from OSHA)
Pulling the air through the coil is usually preferred and most air handlers used to be made that way. If air is pulled through the coil, you get better air distribution across the coil.
The air flow can be converted without issue if the installer follows all the steps.
With a pull through air handler hang it high enough to leave plenty of room for a trap. You don't want to bury the trap in the floor joists0 -
Bryant Evolution and Carrier Infinity are the same .... you will like it. Did you price out the 5 speed ? In NJ an PA the 5 was quite a savings vs the full VS Greenspeed unit .... The 5 will not go down as cold as the Greenspeed -- but, like you I don't need it to as the house has other heat source.Larry (from OSHA) said:I’m taking the plunge on the Bryant Evolution inverter system. Serious overkill for sure but it’s getting hotter and more humid here in Minneapolis. Now I can say both my heating and cooling systems are modulating and condensing.
I will say this. When it was first installed I was doing work on the house and the boiler was down one of the times when the temps went to zero and it was putting out very warm air. Impressive -- I needed it for about three days and it was on 4 or 5 almost the whole time.0 -
It's a nice system ..... The 4" filter is a nice upgrade IMO. The setup is slick as the system goes through self checks and duct CFM checks.Larry (from OSHA) said:@Tag - The one I'm getting is the 5 speed.
Thanks to everyone for all the advice.
There are also lockout setting that have to be looked out .... one of them will keep it out of 1st stage. Since all of mine are zoned and I use them on low fan setting I wanted to make sure we had first stage. I can really see the difference with constant circulation -- the temp all over the house is more uniform. I use it all year --- even with the radiant.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
