Why is Neighbor's A/C making Cicada and A-10 "Brtt" sounds?
Steamback
Member Posts: 39
Apologies, I'm a hydronic guy. I did work on A/C units like 20 years ago, but forgot everything.
My Neighbor has an outdoor A/C unit which every 2-3 minutes makes a loud hissing Cicada-like sound for 30 seconds followed by a loud "brrrrrrt" sound like from an A-10 cannon for a few seconds. Very regularly. Like clockwork.
Is this a common problem? Honestly, I can't believe his A/C is still working...it sounds like the outdoor compressor is killing itself.
What's happening?!
What's happening?!
what does a cicada sound like???0
Sounds like @Steamback's neighbors A/C unitpedmec said:what does a cicada sound like???
Dah!
almost like a cricket but different.
Here is a videohttps://www.youtube.com/watch?v=cprkGk_KW0o
And like the Cicada, your neighbors air conditioner may be ready to mate with a Female A/C. The opposite sex of an A/C unit. The reverse cycle A/C
AKA Heatpump
And just like the Cicada, after the A/C finishes making that noise and finds a mate, the unit will just die.
Isn't nature just great!Edward Young Retired
JUGHNE said:Cicada could sound like a high pressure relief valve opening and then the "brrrr" sound the valve closing and compressor continuing to run. It may die soon.
The Cicada noise could be a vibration or rusty motor shaft, the unit not level. The A-10 could be the contactor chattering.0
- 87K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 389 Solar
