Pex for air?
MikeL_2
Member Posts: 543
Hi all,
Anyone have experience using aqua pex for compressed air piping?
Yes I’ve used many times just follow the manufacturers operating specifications1
We use it at the shop and this was actually a concern so from the compressor to the refrigerated drier is copper and then out of the drier is 1" pex.hot_rod said:Just watch the temperature and pressure ratings. Compressed air gets fairly hot, unless you use a cooler on it.
That copper coming out of the tank gets pretty hot.......Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Isn't plastic with compressed air discouraged because it can break in to pieces that can get loose and become projectiles if it breaks?0
I looked around the PPI site for compressed air application. This report is mostly about testing with air or nitrogen. Maybe best to check with the tube manufacturer. I suspect different listings would be needed for compressed air use?
https://www.plasticpipe.org/common/Uploaded files/1-PPI/RECOMMENDATIONS/Recommendation F.pdfBob "hot rod" Rohr
Living the hydronic dream1 -
I have seen a blue colored PAP listed for compressed air. It was put in a large repair shop by the compressor manufacturer, a German brand compressor and piping system, Kaeser as I recall.
RapidAir is another brand of listed plastic compressed air tube.Bob "hot rod" Rohr
Thanks everyone! I convinced the owner of a nearby woodworking shop to replace the existing compressed air piping. It was changed from galvanized to pvc a decade ago.....0
With what will her replace it with? I'd be careful not to suggest a product that is not listed for theMikeL_2 said:Thanks everyone! I convinced the owner of a nearby woodcworking shop to replace the existing compressed air piping. It was changed from galvanized to pvc a decade ago.....
application. Certainly the PVC needs to go.Bob "hot rod" Rohr
- 50 Industry Classes
