Pex for air?
MikeL_2
MikeL_2 Member Posts: 545
Hi all,
       Anyone have experience using aqua pex for compressed air piping?
  • EzzyT
    EzzyT Member Posts: 1,380
    Yes I’ve used many times just follow the manufacturers operating specifications
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
    GGross
    hot_rod Member Posts: 27,862
    Just watch the temperature and pressure ratings. Compressed air gets fairly hot, unless you use a cooler on it.
    MikeL_2
    Jamie Hall Member Posts: 27,584
    I hope it works. My maintenance garage is full of it...
    MikeL_2
  • ChrisJ
    ChrisJ Member Posts: 17,520
    We use it at the shop and this was actually a concern so from the compressor to the refrigerated drier is copper and then out of the drier is 1" pex.
    That copper coming out of the tank gets pretty hot.......
    mattmia2 Member Posts: 17,487
    Isn't plastic with compressed air discouraged because it can break in to pieces that can get loose and become projectiles if it breaks?
  • PC7060
    PC7060 Member Posts: 1,845
    Yes for PVC but pex should be fine since it doesn't fragment in a failure event
    I looked around the PPI site for compressed air application. This report is mostly about testing with air or nitrogen. Maybe best to check with the tube manufacturer. I suspect different listings would be needed for compressed air use?
    https://www.plasticpipe.org/common/Uploaded files/1-PPI/RECOMMENDATIONS/Recommendation F.pdf
    I have seen a blue colored PAP listed for compressed air. It was put in a large repair shop by the compressor manufacturer, a German brand compressor and piping system, Kaeser as I recall.
    RapidAir is another brand of listed plastic compressed air tube.
  • MikeL_2
    edited June 2022
    Thanks everyone! I convinced the owner of a nearby woodworking shop to replace the existing compressed air piping. It was changed from galvanized to pvc a decade ago.....
    MikeL_2 said:
    Thanks everyone! I convinced the owner of a nearby woodcworking shop to replace the existing compressed air piping. It was changed from galvanized to pvc a decade ago.....
    With what will her replace it with? I'd be careful not to suggest a product that is not listed for the
    application. Certainly the PVC needs to go.
