Mysterious duct.
gyrfalcon
Member Posts: 189
Any ideas what this duct is for? Besides being a major problem? It’s hot and muggy around here. This is probably not helping!!
Slant Fin Galaxy GG100(1986) , 2 zone hot water baseboard, T87 Honeywell thermostats.
Not a clue. Any access to it from above? Is air entering or leaving it? You may have to try blowing smoke or scent (peppermint works) into it with a fan to see where it heads!Br. Jamie, osb
Is that a kitchen? looks like an old kitchen exhaust fan or just random exhaust fan, possibly that had the motor removed a long time ago.0
judging by the infrared camera i'm thinking maybe a vent for the attic, if there is an attic above.0
Cathedral ceiling / clerestory in kitchen. Makes a dead zone for air movement. No ac regester or return in kitchen. With AC on and really hot days, the wall sweats. Looks like the pipe goes to the wall area. I can’t see much beyond that. Can I just cover it up or fill with insulation ? There is another strange duct like this one in my living room area. Someone (several previous owners ago) had some wacky ideas they tried to implement, poorly.Slant Fin Galaxy GG100(1986) , 2 zone hot water baseboard, T87 Honeywell thermostats.0
I have seen similar registers that are barometric relief dampers for evaporative coolers."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
I see no outlet, wiring, controls or any other related items. Any reason I cannot insulate and seal it off?Slant Fin Galaxy GG100(1986) , 2 zone hot water baseboard, T87 Honeywell thermostats.0
It's your home. I can't see why not.gyrfalcon said:I see no outlet, wiring, controls or any other related items. Any reason I cannot insulate and seal it off?
Is this a manufactured home? Those homes can be low on combustion air availability and therefore have these installed to compensate. Other than that, I can't see any danger in sealing up those holes.
Do you have any fossil fuel appliances in your home? Gas range, oil or gas furnace, Gas fired water heater, Gas fireplace, or wood stove are some examples. If yes, then I would make the vent cover a temporary insulation for now and test the home for Carbon Monoxide in the heating season.Edward Young Retired
have a blower door test done on the home. Then cover the vent to see what a difference it makes. It must go somewhere.
Can you get a ladder and see if it sucks or blows
If you cover it, it might be nice to know where the other end of the duct is.Bob "hot rod" Rohr
I have gas appliances and a wood burner. Boiler room has outside air pipe into the room. I will look a little more and see what I find.Slant Fin Galaxy GG100(1986) , 2 zone hot water baseboard, T87 Honeywell thermostats.0
Could be anything. We were working in a church once and there was a questionable duct they thought they could remove- turned out it was the output of the pipe-organ blower!All Steamed Up, Inc.
Consulting4
- 50 Industry Classes
