Loud fan noise from the AC unit outside
tomtomtom
Member Posts: 35
Happy Friday everyone!
My AC is working and cooling the house but it has really loud noise. You can watch the video here
One of the air vents in the bedroom also has a strange sound when spinning
Is there anything I can do? Thanks
it actually sounds like your evaporator might be frozen and your slugging refrigerant back to the compressor. i really can't make it out but it looks like the suction might be frozen inside the condenser below the fan. frozen coil doesn't make sense if your haven't noticed any lack of air but if its overcharged it would do the same thing but im assuming you wouldn't be on here asking if you had a tech there before the post. thats why im leaning the other way1
Thanks everyone! Looks like it's time to call a contractor as everything you all said were way over my head
bad motor capacitor?0
