Completely cover baseboard heater
elrayle
Member Posts: 3
I have a baseboard hot water heater in a small closet used for storage. It gets way too hot in the closet. Can I box in the heater with rigid foam board type insulation? This would stop the air flow and the radiating off heat out into the closet. Are there any risks? The other option would be to remove the heater. I have to keep the pipe as it feeds the heater in the adjoining room. Other suggestions are welcome.
Could cut the aluminum fins off, that would reduce the output significantly. Unfortunately the copper pipe will still emit some heat.
Could start by simply laying cardboard strips on the top of the fins and see how it goes. I would guess this will reduce the output by about half.0 -
Thanks for the feedback. I think I’ll try boxing it in first and see how it goes. I can always remove it later.0
Thought I’d post before and after pics in case that impacts opinions.
Safest way is to wrap the fins in aluminum foil. This will block the airflow across the fins and reduce the heat output0
Why not just remove it? No ugliness.
- 87.2K THE MAIN WALL
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 75 Pipe Deterioration
- 6.4K Radiant Heating
- 15.6K Strictly Steam
