Wire damper to thermostat without panel zone
Lestat
Member Posts: 2
Hi. Urgent I need help for connecting the damper to the thermostat without panel zone.just I need to know where can I connect the wires form the damper to thermostat . Thank you
You're not giving us enough information or pictures. No x-ray vision here. You have to give us something to go on0
That's just a bit vague. What type of heat? What damper? What thermostat? Power supply for thermostat? And so on...Br. Jamie, osb
Just I’ve thermostat and damper M1M 4 M 60
M1- Common
M4- power open
M6- power close
In what scenario do you need to just operate a damper?
Not all thermostats can be set up for open/close on temp drop/rise or vice versa in one mode.0 -
Does this help?
- 123 Chimneys & Flues
