Wire damper to thermostat without panel zone
Lestat
Lestat Member Posts: 2
Hi. Urgent I need help for connecting the damper to the thermostat without panel zone.just I need to know where can I connect the wires form the damper to thermostat . Thank you
    EBEBRATT-Ed Member Posts: 21,004
    You're not giving us enough information or pictures. No x-ray vision here. You have to give us something to go on
    Jamie Hall Member Posts: 27,798
    That's just a bit vague. What type of heat? What damper? What thermostat? Power supply for thermostat? And so on...
  • Lestat
    Just I’ve thermostat and damper M1M 4 M 6
    HVACNUT Member Posts: 7,673
    M1- Common
    M4- power open
    M6- power close
    In what scenario do you need to just operate a damper?
    Not all thermostats can be set up for open/close on temp drop/rise or vice versa in one mode.
    EdTheHeaterMan Member Posts: 12,734
    Does this help?
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,363
    @Lestat, I've merged your duplicate posts into one post here. Thanks.
    President
    HeatingHelp.com
