What is this protrusion from boiler?
Ldallas_87
Member Posts: 18
I was looking for a tapping for a probe type LWCO but only saw this. Can anyone tell me what it is for?Also I noticed that the installer didn’t use the normal tapping for the lower gauge glass fitting and tapped a hole above it. Has anyone ever seen this done and is there a reason for it? I appreciate any input.
1
Make and model of the boiler would help. Everything I can see looks like it's properly installed.
What is the issue? You want to get rid of the MM #67 low water cutoff and go electronic?0 -
It’s an Enerjet, installed around 1987 but I am unsure of the model (missing label). Yes I was thinking of going electronic with a probe LWCO.Glad it looks properly installed to you. What is the reason to have two locations to insert bottom gauge fitting? Just curious about that.0
https://hydrolevel.com/wp-content/uploads/2018/12/711-Series-Instructions-web.pdfer
Take a look at the above which may solve your problem.
I would have to see the MFG specs on the boiler to know what all the tapping's are for. Some boilers could be used for water or steam, so they had extra tapping's.
Looks like you could use this0 -
Thank you!0
The steamaster water color and that drain on the gauge glass make me think someone here did that work, unless that all came from you?
Where are you located roughly? Just a general area is more than good enough.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I’m in Brooklyn, NY. Yes I installed that with the help of this forum and YouTube.0
No one addressed the "protrusion" query. I believe it is one of the holes in the sand mold where the liquid cast iron is poured into the mold at the foundry. But I could be mistaken.
Why is the cabinet cut?0
He was looking for a tapping for the probe type LWCO and wanted to see what that bump was. Probably found that the jacket was not depressing as much as it did where there were no bumps. This is just speculation but I think the owner has a pair of tin snips. Just sayin'pecmsg said:Why is the cabinet cut?
- 117 Geothermal
