Solar hot water
2»
    hot_rod Member Posts: 27,426
    power to weight ratio, is what determines 1/4 mile times. This graph, assumes perfect conditions, no tire or clutch slip, fast shifts. Here is the horsepower to get you there.
    Solid_Fuel_Man
    Jamie Hall Member Posts: 27,333
    When one thinks back to those grand old days, the wonder is that we could run as fast as we did (I quoted 10 second times, but I doubt I ever really was that fast! Memory has a way of doing that...)(Lady, my Buick GS, was 3200 pounds and that 401 really did put down 340 honest horses at the wheels -- so 12.5 or so is probably about right). Considering the tires we ran and the transmissions (fast shifts? Even with a Hurst they were pretty slow!). The only good thing was the clutches didn't slip, at least not much -- but they took a strong left foot to disengage!
  • JakeCK
    JakeCK Member Posts: 1,502
    That power to weight chart doesn't go to 6000lbs. :(
    Supposedly my 13 f150 has 360 horses galloping under the hood. But it wasn't geared to jump off the line.
