Radiator Repair
egrant1
Member Posts: 1
Does anyone know of any companies that could repair a pushnipple leak on a steam radiator
I dare say that most of us who have had the problem have done it ourselves.Br. Jamie, osb
@egrant1 , where are you located?All Steamed Up, Inc.
Consulting0 -
Here is a possibility.
Purchase radiator stop leak at your local automotive supply house.
Close the inlet valve to the radiator, make sure the stop leak is in liquid form . Remove the the vent valve from the radiator. Make a funnel with 1/8 or 1/4 nipple and elbow, increase ti at least 3/4" pipe with a 3/4" coupling and pour the stop leak into the radiator. Put enough of the stop leak solution to cover all the push nipples for at least a week. Then open the radiator valve and the solution drain back toward the boiler. Put the radiator back into service and hopefully the leak will have stopped.
jakeSteam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron0 -
Does anyone know of any companies that can repair a push nipple leak on a steam radiator? Looking for reliable recommendations.
As I said a year or so ago — most of us who have done it have done it ourselves. "A push nipple leak" though is a bit vague — one would have to take the sections apart to see why it's leaking to figure out what to do about iit.
Do it your self. Get a can of waterglass about a quart. pour it in fill with HOT water seal it up with plugs one plug with a schrader valve and put 30psi to it. It often works.
