Radiator Repair
Does anyone know of any companies that could repair a pushnipple leak on a steam radiator
    Jamie Hall Posts: 27,734
    I dare say that most of us who have had the problem have done it ourselves.
    Steamhead Posts: 18,830
    @egrant1 , where are you located?
  • dopey27177
    dopey27177 Posts: 916
    Here is a possibility.
    Purchase radiator stop leak at your local automotive supply house.
    Close the inlet valve to the radiator, make sure the stop leak is in liquid form . Remove the the vent valve from the radiator. Make a funnel with 1/8 or 1/4 nipple and elbow, increase ti at least 3/4" pipe with a 3/4" coupling and pour the stop leak into the radiator. Put enough of the stop leak solution to cover all the push nipples for at least a week. Then open the radiator valve and the solution drain back toward the boiler. Put the radiator back into service and hopefully the leak will have stopped.
    jake
  • Alaxavand
    Alaxavand Posts: 2
    Does anyone know of any companies that can repair a push nipple leak on a steam radiator? Looking for reliable recommendations.
    As I said a year or so ago — most of us who have done it have done it ourselves. "A push nipple leak" though is a bit vague — one would have to take the sections apart to see why it's leaking to figure out what to do about iit.
  • Grallert
    Grallert Posts: 1,184
    Do it your self. Get a can of waterglass about a quart. pour it in fill with HOT water seal it up with plugs one plug with a schrader valve and put 30psi to it. It often works.
