Watts vs Amtrol
Thanks.
In my opinion they are all pretty much equal these days. Amrtol is the only brand we used for residential since I started in the 1980s. We seem to be replacing them more often these days.
About 30 bucks more for these plastic lined with a brass nipple
properly sized and installed, with good boiler water a plain steel tank should last 10, 15 maybe 20 yearsBob "hot rod" Rohr
I can't remember what brand it was, (but it was panted green) a manufacturers rep told me once that their tank was charged at the factory with Nitrogen. At the time I had just learned about how oxygen can migrate thru solid objects like Plastic Tubing. (The reason you need "O2 barrier" PEX on CI boiler systems). so I believed it was a worthwhile feature. I requested that brand for a while, but would take whatever brand was available.
I did replace more Amtrol tanks that any other brand in my career, but I thing that is because there were more Amtrol tanks on jobs than any other brand.Edward Young Retired
I've asked a few tank manufacturers if nitrogen was ever used for pre-charging, nobody remembers that? Amtrol, possibly others use chilled or air that has gone through a refrigerated moisture remover.EdTheHeaterMan said:I can't remember what brand it was, (but it was panted green) a manufacturers rep told me once that their tank was charged at the factory with Nitrogen. At the time I had just learned about how oxygen can migrate thru solid objects like Plastic Tubing. (The reason you need "O2 barrier" PEX on CI boiler systems). so I believed it was a worthwhile feature. I requested that brand for a while, but would take whatever brand was available.
I did replace more Amtrol tanks that any other brand in my career, but I thing that is because there were more Amtrol tanks on jobs than any other brand.Bob "hot rod" Rohr
Living the hydronic dream1 -
Bag type tanks last longer, cost more usually. They have better acceptance than the diaphragm tanks also.Bob "hot rod" Rohr
Some big buildings pressurized conventional tanks with nitrogen. At the time seemed odd. But as decades go by anything that delays rust/scale looks prudent.0
I think the rep was from BJ Terroni, who handled Taco Pumps. I also remember winning a color TV from them for being one of the 4 fastest technicians to change out a Taco 007 pump cartridge at the Service Managers Convention in Hershey PA in the 1980s. Did Taco ever sell an expansion tank. I remember the tank color Green.hot_rod said:
I may be remembering incorrectly. But I did use my dry nitrogen bottle to recharge expansion tanks many times because of that memory. Thanks for looking into that Bob... So some people really do read my comments
Mr.Ed
YesI have seen Taco expansion tanks. I'm not sure if they manufactured them or out sourced. I believe they have a fab shop for welded steel vessels.EdTheHeaterMan said:
Mr.Ed
Amtrol is owned by Worthington now, they are about the largest tank manufacturer from freon tanks, Mapp gas, LP, to large compressor tanks, etc.Bob "hot rod" Rohr
Many commercial jobs I've put Taco tanks in. They are always a sandy red. Made in Cranniston RI I believe...
Not sure about the resi ones like Bob mentioned.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
HTX is a horrid green, been buying them at Webb's for quite a few years and have yet to replace one in the field, $10 clams more than an Amtrol from Webb's....0
- 117 Geothermal
