THERMOPRIDE OL5-85
JETDOC33
JETDOC33 Member Posts: 1
I HAVE THERMOPRIDE OL5-85 THAT'S 22 YEARS OLD AND IVE HAD TO REPLACE A FEW PARTS; IS IT TIME FOR A NEW UNIT?
    pecmsg Member Posts: 7,027
    Age alone tells you nothing. How was it set up, temperature rise, stack temperature, Static pressure, combustion analyses on and on.
    Thermo Pride is a TANK!
    EBEBRATT-Ed Member Posts: 20,103
    Thermopride is the best oil furnace.
    Unless the heat exchanger is suspect I would keep it
    STEVEusaPA
    HVACNUT Member Posts: 7,418
    Thermopride is the best oil furnace. Unless the heat exchanger is suspect I would keep it
    Agree Thermo Pride is one of the best but I had one just last week with a crack heat exchanger. Fairly new account. This furnace is zoned, without a bypass, so I'm sure heat rise was a contributing factor.
    So @JETDOC33, get it serviced every year and the answer will be on the combustion test.
    What burner? The one I worked on had a Beckett AF.
    EdTheHeaterMan Member Posts: 12,084
    The Heat Exchanger has a lifetime warranty. Did you contact Thermo Products for a new HX? I have had zero problems with ThermoPride HX Warranty. I changed out 2 in my lifetime of HVAC work. Easy apart and easy together. One of them was really old at the time!
    Yup, the client is getting a brand new heat exchanger. Wrapped in a 21st century complete furnace.
  • SuperTech
    SuperTech Member Posts: 2,658
    Thermopride makes the best furnace available, regardless of fuel choice. I don't think there's any other furnace available that is as reliable and well built. If you have one in your home consider yourself lucky. It will probably outlast you.
    MikeAmann
