THERMOPRIDE OL5-85
JETDOC33
Member Posts: 1
in Oil Heating
I HAVE THERMOPRIDE OL5-85 THAT'S 22 YEARS OLD AND IVE HAD TO REPLACE A FEW PARTS; IS IT TIME FOR A NEW UNIT?
Age alone tells you nothing. How was it set up, temperature rise, stack temperature, Static pressure, combustion analyses on and on.
Thermo Pride is a TANK!0 -
Agree Thermo Pride is one of the best but I had one just last week with a crack heat exchanger. Fairly new account. This furnace is zoned, without a bypass, so I'm sure heat rise was a contributing factor.EBEBRATT-Ed said:Thermopride is the best oil furnace. Unless the heat exchanger is suspect I would keep it
So @JETDOC33, get it serviced every year and the answer will be on the combustion test.
What burner? The one I worked on had a Beckett AF.0 -
Agree Thermo Pride is one of the best but I had one just last week with a crack heat exchanger. Fairly new account. This furnace is zoned, without a bypass, so I'm sure heat rise was a contributing factor.HVACNUT said:EBEBRATT-Ed said:Thermopride is the best oil furnace.
The Heat Exchanger has a lifetime warranty. Did you contact Thermo Products for a new HX? I have had zero problems with ThermoPride HX Warranty. I changed out 2 in my lifetime of HVAC work. Easy apart and easy together. One of them was really old at the time!Edward Young Retired
Yup, the client is getting a brand new heat exchanger. Wrapped in a 21st century complete furnace.EdTheHeaterMan said:
What burner? The one I worked on had a Beckett AF.1 -
- 120 Geothermal
- 169 Indoor-Air Quality
