Oil Distribution Line(s)?
There was most likely an oil tank sitting on the floor where those lines come out of the floor.0
There was a tank in the basement... but why is the line a loop, with both ends cemented in the ground? Thanks!0
the basement walls are patched about 15 feet away from this line, where the basement tank was. But buyers are still convinced there's a hidden underground tank, due to this specific fuel line0
Oh, I thought it was 2 pieces, but it is just one piece in a loop. Maybe someone put it there for a future feed to something.0
so this "loop", doesn't indicate to you, underground tank? And also probably did not belong to the basement one either? House was built 19630
@wien825
It points to an oil tank only because of the size of the copper tubing.
If the house was built in 63 and the indoor tank was removed more than likely that removed tank was the original tank and there never was an underground tank.
Look around where the old tank was located and search the floor. You will probably find the oild oil line cutoff flush with the floor, same around the boiler.
You could cut the loop and put air pressure on it to see if you can find where they go but don't know what else it could be.
It is very unusual to have a unsplice loop like that0 -
You have a dilemma. Say you find there is a tank and the seller backs out. Now you know about it and you must disclose to each prospective buyer in the future. If however you cut those lines below the surface and patch the floor so there is no evidence of those lines, who is going to know? It is a sellers market... so do you want to know?
When you cut that line and refrigerant shoots out, you will know it is not oil. If you cut that line and find water shoots out, then you will know it is not oil. If you cut that line and it smells like oil... Then you can decide the next step.
Just some random thoughts.
EDIT: What if I was pouring concrete back when the house was built and didn't know if I wanted the tank in the garage or the basement. For the cost of a roll of copper, I could decide later. After the basement tank was installed, I could just never use that copper tubing. Way back then, who'd a thunk it would be such an issue today?Edward Young Retired
What about gas?EdTheHeaterMan said:You have a dilemma. Say you find there is a tank and the seller backs out. Now you know about it and you must disclose to each prospective buyer in the future. If however you cut those lines below the surface and patch the floor so there is no evidence of those lines, who is going to know? It is a sellers market... so do you want to know?
Just some random thoughts.0 -
Thanks all! I guess we'll see when they bring in the GPR scan. I just can't believe this is now becoming such a huge issue, especially since no one can confirm exactly what this loop is.0
I hope the buyer is paying for the GPR...0
Ask them to kindly prove it's a fuel line.wien825 said:the basement walls are patched about 15 feet away from this line, where the basement tank was. But buyers are still convinced there's a hidden underground tank, due to this specific fuel line
I would've been curious in 2014. How many times have you tripped on it and wondered what it was?0 -
It's unusual to say the least. @wien825
Did you find any evidence of the old lines from the indoor tank?0 -
@EBEBRATT-Ed I did not, I only see the patches in the foundation. The basement tank leaked in 2008, and there was a cleanup/excavation, so maybe those lines were excavated? The furnace was also replaced. I don't see anything else in the floor. Mystery continues! I won't be able to sleep until this GPR is over with
I would cut it out and paint it over. If crude starts gushing, you could be rich.0
- 120 Geothermal
