All corroded
brandonf
brandonf Member Posts: 224
Hey  everyone. This isn't my buddy's house and every single piece of metal no matter what it is as corrosion on it in his basement. Oil heat, electric hot water, well water with four filters.   Nails, screws, electrical boxes, steel, copper, brass, aluminum, every single thing has tons of corrosion on it. All the copper pipes are green and the house is less than 30 years old.
This is in Rhode Island and it's a full poured concrete basement.
The land does have a high water table and when it rains he occasionally gets a little bit of water in a corner but not more than a small puddle.
He's also getting a light green fuzzy mold on a lot of things for no apparent reason.
Any thoughts? All help is appreciated.
Homeowner, Entrepreneur, Mechanic, Electrician,
"The toes you step on today are connected to the butt you'll have to kiss tomorrow". ---Vincent "Buddy" Cianci
    Steamhead Member Posts: 18,319
    High humidity.
    Consulting
    Larry WeingartenSTEVEusaPAkcopp
    pecmsg Member Posts: 6,881
    He needs a dehumidifier run to a drain.
    MikeAmannkcoppPC7060
  • neilc
    neilc Member Posts: 3,140
    is the dryer vent in one piece, and to the outdoors?
    known to beat dead horses
    kcoppPC7060
    mattmia2 Member Posts: 15,995
    Is this near the ocean? Possibly using drywall that was made with ash?
    An old way of checking is place an old leather shoe or glove on a shelf or wall in the basement, if it grows mold the humidity is too high.
    reggi
  • brandonf
    Funny thing you say that one of his leather boots is growing mold.
  • brandonf
    It's about a half mile from saltwater
  • brandonf
    Not sure but I will check that out
