Can kitchen oven be under gas pipe in ceiling?
tnakae
Member Posts: 2
in Gas Heating
Remodeling the basement and the only good place in kitchen area for stove is directly under black steel gas pipe in the ceiling. There will be a vented range hood over stove and under pipe. Is this against code? A bad idea??
I don’t believe so, that pipe is designed to withstand more heat than what you might encounter in a normal operating kitchen. I can’t be sure though. There is a contributor that has considerable gas code knowledge, but I can’t think of his screen name. Perhaps someone else may help to tag him to respond
Thank you!!0
