Thermostat is buzzing loudly
David777
Member Posts: 2
in Gas Heating
My thermostat in the basement that going to my Furnace is buzzing loudly loudly.why? And should I be worried
A little more detail might be helpful... what kind of thermostat? What kind of furnace? What does the thermostat control? How is it powered?
Yes you should be worried -- neither a thermostat nor a furnace should buzz. And I can't think why a thermostat should buzz...Br. Jamie, osb
It's a Meyer furnace.old.. thermostat is a Honeywell. And I'm doing most of this by guessing cause both are so old to the point to where I can hardly see any markings. The furnace doesn't buzz but the thermostat which which I'm only me guessing but but after reading a bunch of forms on here if you guys talking back-and-forth I'm back in force I'm 90% sure 99% sure that is that is the thermostat It is vibrating or buzzing Intellectric the Furnace's gas0
I think a couple of pictures are in order here.
The thermostat is the gadget on the wall somewhere which controls the heat... I'm not sure what gadget we're talking about here.Br. Jamie, osb
- 15.8K Strictly Steam
