What is the MIN/MAX water temperature of this radiator?
pieIX
Member Posts: 12
Some people say 100F other 90F...
There generally rated at 180* F but will operate with any temperature above 32*0
Temperatures below 0°C (32°F) may cause separation of some molecules to a point of loosing ability to maintain a proper water/steam pressure seal. (freezing may cause a crack)
Water temperature above 121°C (250°F) may cause pressure above system normal operation. But the radiator will probably survive the occurrence, however. the relief valve may fail.
What a shame using a cast iron element in a convector for hot water ... It covers the best part
Thank you for your answers.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
