How to unlock this radiator valve?
pieIX
Member Posts: 12
in Gas Heating
The valve doesn't turn either way.
Try backing off the packing nut -- the hex just under the handle -- just a little and see if you can get anywhere.Br. Jamie, osb
It's a butterfly valve , quarter turn on and quarter turn off . That metal rod attached to the underside of the handle was there to catch the two cast stops on the body of the valve ... Until someone unknowing over closed the valve and forced the rod out of the way .
So, if I understand what Big_Ed_4 wrote. If I use a screwdriver and I insert it at the red arrow below the metal rod. And I put pressure in the direction of the blue arrow to bend the metal rod. I would be able to turn the handle in the direction of the green arrow? And can I balance the radiator that way?
Yes that may work to turn the handle. But can you turn the handle in the other direction currently? if you can, then just turn it the other way. As far as balancing using that valve, you may find it difficult to get accurate balancing.
Is the room too hot where that radiator is located? Try covering the radiator with a blanket. Don't worry about a fire, that radiator will not get hot enough to burn the blanket. If that solves the problem, you can have a radiator cover made to fit that radiator and close off the opening to reduct the amount of heat from that radiator.
No, the valve doesn't turn either way. This is why I thick it is block by the rod.0
If you take the handle off you may be able to take that tab off the stem, put the stem back where it belongs between the stops, and put the tab back on.0
If it does not turn , then it needs to be taken apart , clean and greased . The system pressure needs to be dropped .... If the radiator is working and the valve is not leaking , then just leave it alone .. It is not a valve to adjust flow . It is on or off ... The rod and stop is to set it in either direction . On or off...
If I can not balance the radiator with this valves, what would be the ideal temperature in the input, output and especially the difference between the two?
EDIT:
This is the radiator.
the ideal input temperature depends on the heat loss of the room . The heat loss increases as the outside temperture decreases below the room temperture ... Since the radiator is a convector , you can balance radiator with temperture and air flow ...
