What is the MIN/MAX water temperature of this radiator?
pieIX
pieIX Member Posts: 12
edited February 2022 in Gas Heating
Some people say 100F other 90F...
    Jamie Hall Member Posts: 27,359
    Say what? You can run that puppy right up to 212 F (boiling water) if you want to. I wouldn't chill it down much below 35, though... it might freeze.
    pecmsgkcoppflat_twin
    pecmsg Member Posts: 7,055
    There generally rated at 180* F but will operate with any temperature above 32*
    EdTheHeaterMan Member Posts: 12,158
    Temperatures below 0°C (32°F) may cause separation of some molecules to a point of loosing ability to maintain a proper water/steam pressure seal. (freezing may cause a crack)
    Water temperature above 121°C (250°F) may cause pressure above system normal operation. But the radiator will probably survive the occurrence, however. the relief valve may fail.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,530
    What a shame using a cast iron element in a convector for hot water ... It covers the best part
    hot_rod Member Posts: 27,446
    When the surface temperature is above the ambient temperature where it is located it will transfer heat.
    Rich_49
  • pieIX
    Thank you for your answers.
