Reading the manual
pecmsg
Member Posts: 6,620
Asked by a friend to look at a replacement steamer in his fathers house
if the installing contractor won’t correct it I’ll do it in a few months.
Is it really that hard to read a manual
If it's that hard, it means (all together now)- you can't fix stupid!pecmsg said:Is it really that hard to read a manual
Consulting6 -
I’m giving the installing contractor a chance to do it right.Disconnect
drop header
venting
not much can be done about the sizing. The owner will get the EDR for me.If not improved or if he says no then once the weather breakers we’ll do it.I believe it was a family friend / relatives did the install0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
